Head bolts
phil2144
Stift
Bundesland / Kanton: Cheshire
Land: United Kingdom
Head bolts
#1 Beitrag von phil2144 » 27. Januar 2022, 23:07
Hi guy's
I am interested in what make head bolts people are using, part number 049 103 385 for the WR engine? And any feedback on how they have been once used?
Regards Phil.
Rantanplan
Bundesland / Kanton: Saarland
Re: Head bolts
#2 Beitrag von Rantanplan » 28. Januar 2022, 12:41
Hi Phil,
I hope I understood your question correctly. I used head bolts from Elring M 11x1,5x98. The head bolts are expansion screws, for this reason you can only use them once.
Michael
phil2144
Stift
Re: Head bolts
#3 Beitrag von phil2144 » 28. Januar 2022, 23:56
Hi Michael
Yes you understood correctly, and I am aware they are single use only. So how long have they been fitted on your engine?
The main reason for this post is to find out what make of aftermarket head bolts are the best to use and ones NOT to use.
Does anyone else have a input on this topic ?
Phil.
Patrick20V
Re: Head bolts
#4 Beitrag von Patrick20V » 8. Februar 2022, 22:17
What about the ARP Bolts? Not only for single use. Works well in my 20V.
Re: Head bolts
#5 Beitrag von wego0002 » 9. Februar 2022, 01:59
Hello Phill,
in short, do not buy the cheap AM CCP crap. :naughty: :naughty: :naughty: :naughty:
Most of these bolts are undersized. Meaning, they are ø0.2mm to ø0.4mm smaller then the OE M11x1.5. You don't even know if they meet any criteria like the stretching part. I stripped out a short block once, so to say, I found it out the hard way. :oops: :oops: :oops:
Get the OE bolts from your friendly AUDI dealer. Not cheap but better then..... you know. :D :D
